I am performing a dynamic explicit analysis in Abaqus, with contact, to capture the post-buckling behavior of cold-formed steel lipped channel section of 1 m height. I have modeled discrete rigid 3D shell plates at both ends. The boundary condition is top pinned, bottom fixed and applied 250mm displacement with a tabular amplitude for a time period of 2 sec. This time period is more than a 3xtime period of the system(I calculate with a natural frequency analysis first).
I am checking the ratio of kinetic energy to the internal energy of the system, which should be below five percent as per the guide-line when we perform a pseudo-static analysis so that the inertia effect is not dominant.
I am getting the below result for the initial few time steps:
1. For the First time step, Internal energy =0, Kinetic energy=119.6, Can this happen? If this is erroneous, what should I do to mitigate this?
2. For the next 18 time steps the ratio of internal energy to kinetic energy gradually reduces from 22 % to 5%, and for the rest of the time steps, it is less than 5%.-Is this result acceptable, or do I need to increase the time period by more than 2 sec to reduce the inertia effect?
Could anyone help with this?
Thanks in advance!
Thanks in advance!
