I am starting to study composite beams and I have some doubts on this subject.
First, from my understandment, as long as I am only working with positive moments I can consider both primary and secondary beam as composite beam. If I am working with moment frame beams I should ignore composite action and design as simple steel beam. Also, all the beams should have stud bults, including moment ones. Are those assumptions correct?
And what about axial load verification, should I take this in concideration? I have lateral wind loads acting on columns. If so, what about the unbraced length of the beam since the span is almost 9m, should I take this in consideration or the slab has some influence on this?
From my studies I've heard of diaphragm effect of the slab that I think has some relation to this.
Thanks in Advance!
