Due to some reasons using clip angle for the HSS isn't possible and is instructed to use HSS single angle connection (welded or bolted) to the other beam.
The load transmitted will only be vertical shear I'm wondering if will there be any issue or additional checks required especially for the angle since it might twist or something close to the idea?
The load isn't that large around 5 kips.
[Edited] Here's the sketch. Cant seem to attach it.
Thank you.
Thank you.
