S.R. Shah
Industrial
- Jun 2, 2017
- 2
Hi Good Morning. A client requested that our technicians test and certify one of their valves (new valve), however, while reviewing the Report, I noticed the following;
Original Nameplate Data: Valve: AG Crosby, Set Pressure 100-PSI, Capacity 91-SCFM, CDTP --; Note; No repairs or disassembly of the valve was done as it was a test only. The final record of testing showed that the set pressure was at 129 PSI and No Capacity change, Test Fluid was Nitrogen.
Is this acceptable and within the required codes and standards?
