Hay!
I have a A351 CF8M cast steel which is full of tunder in the corners. I am aware that Hcl is not an appropriate acid but it removes the tinder away easier and mor eeffective as grinding which is not possible due to place problem (corners).
If I apply HCl with a brush for 5 Minutes and after remove itby cleaning it with water andd aölcaline cleaner I am able to remove tinder completely. Will this cause an issue to cast steel?
Thank you
Thank you
