Questions about Abaqus AM Plug-in (convert Gcodes to event series) 1
uolvs
Materials
Sep 16, 2020
8
Hi everyone,
My question is that: after downloading the file generateEventSeries.py,
where should I put it in?
and what should I do to use it to convert my Gcode file to event series files?
As the article 'Toolpath-Mesh Intersection Module and Built-in User Subroutines for Additive Manufacturing Process Simulation' is unavailable from abaqus knowledge base at the moment, I don't know how to operate this step.
I hope someone else can help me!
You can place the script in any directory and then open command line there and type:
abaqus python generateEventSeries.py g-code_file_name roller_pad_dimension delay_between_layers power
where: roller_pad_dimension - extent to which the roller startong point and end point are extended from min Y and max Y coordinate of the model for each layer (value between 0 and 1), delay_between_layers - time taken for the roller to deposit material
Hi FEA way,
Thank you for your help.
But I am still not sure which command line you mean, abaqus command?
By the way, should I put the gcode file together with generateEventSeries.py in the same folder?
To open the command line go to selected directory, press SHIFT+RMB and click "Open command window here" or "Open PowerShell window here" (depending on the version of your operating system).
Yes, the g-code file should be placed in the same location as the script.
Hi FEA way,
According to your method, and I typed:
abaqus python generateEventSeries.py cube.gcode 0.5 10 100
but it shows an ImportError: No module named GcodeReader.
Is there anything I need to edit in the generateEventSeries.py file?
Thank you again in advance.
I attached the error in detail.
Traceback (most recent call last):
File "generateEventSeries.py", line 68, in <module>
import GcodeReader as myGcode
File "SMAPython\SMAPytLibPy.m\src\site.py", line 120, in _numpyHook
"""Append ./build/lib.<platform> in case we're running in the build dir
Try with the smallcube.gcode exemplary file provided in the package that you've downloaded. Keep in mind that the script is designed to be used with g-code generated by ReplicatorG software. Otherwise you would have to edit the script.
Hi FEA way,
There is only one script named 'generateEventSeries.py' in the package, and I didn't find other examples.
I think the main problem is that:
Inside the generateEventSeries.py, I find one line code 'import GcodeReader as myGcode', but I don't have that GcodeReader module in my python side-packages or in the package I downloded.
And I don't know which Gcodereader they used or just written by authors because I haven't find it from PyPI or Github so far.
Did you try that script?
Yes, I used this script on the aforementioned exemplary file (smallcube.gcode). Do you have the GcodeReader.py script in the same folder as generateEventSeries ? It should be provided in the package.
No, there was nothing, just generateEventSeries.py. Would you please share the GcodeReader.py script with me? Maybe also the LayerObjectReader.py. Thanks a lot!!!
I don't know where to download these files again, because the Abaqus knowledge base is unavailable at the moment, and I really don't want to be hindered by this problem.
