BrianE22
Specifier/Regulator
- Mar 21, 2010
- 1,069
I'm trying to get a rotary table I bought years ago for my mill running. It uses a Yaskawa servomotor and encoder. The encoder is marked "incremental". From what I can tell from the documentation I've been able to find there is only one output from the encoder. So without quadrature outputs how does the controller know which direction the motor is running? I'm guessing that the controller just assumes if you command it to go backwards, it actually does and it subtracts counts. Does that seem right to you?
