Has anybody used/created a lisp routine that will allow you to select the objects... then auotmatically, change properties to layer 0, color Bylayer, ltype bylayer and then convert to a block using typed name or anonymus name remove object and insert in same location?
This sounds like a LISP routine, but I am not savy enough to write lisp files...or maybe one already exists that i can manipulate.
Any help would be cool
tzinger
tzinger
