Ishack
- May 8, 2013
- 48
Dear Experts,
QW-408.9 states For groove welds in P‐No. 41 through P‐No. 49 and all welds of P‐No. 10I, P‐No. 10J, P‐No. 10K, P‐No. 51 through P‐No. 53, and P‐No. 61 through P‐No. 62 metals, the deletion of backing gas....is an essential variable for GTAW process.
The point I am getting confused is this variable is applicable for all welds (not only groove weld, but also fillet weld, partial groove weld etc...) a P-No 10I
1. if I have a WPS that was qualified using backing gas for groove weld for P-43 material, will I be able to use it for partial penetration weld without back purging or full penetration weld with backing plate without backing gas?.
2. if I have a WPS that was qualified using backing gas for groove weld for P-10I material, will I be able to use it for fillet weld without back purging or full penetration weld with backing plate without backing gas?.
With simple interpretation of QW-408.9, the above 2 points cannnot be done. But why ASME Sec IX restricted so?.
Even if u see the definition of backing gas in ASME Sec IX is backing gas: a gas, such as argon, helium, nitrogen, or reactive gas, which is employed to exclude oxygen from the
root side (opposite from the welding side) of weld joints.
Everyone opinion is most welcome here
regards
Isa
regards
Isa
