I have some performance qualification test pieces which have come back as 'failed'. The welders are claiming that it is not their welding technique which caused them to fail, but rather the bend radius of the test pieces was too small. I am using SA-516 Grade 70 material with a thickness of 3/4". I see QW-466.1 gives dimensions for for the test jig, however this diagram and the general notes have me rather confused.
Can anyone give me a clue as to what the proper bend radius should be?
