I completed an inspection this week of a small 1 story, 1,250sf home where the client was complaining about their walls. The home is geometrically shaped like a square with a small addition off of the front and back, and the main bearing wall runs from front to back. In her living room, there was a pull-down staircase that led to habitable attic area with a 7' vaulted ceiling and knee walls built 4' in from both side walls. When I was up in the attic, I realized the ceiling joists were constructed from 2"x4"s, the spacing of which I couldn't confirm due to the finished floor but still scary as they spanned over 11'-6". When I went downstairs, I discovered that each wall running front to back, including the exterior side walls and main bearing wall were all racked and leaning toward one side. The side walls were measured to lean 1" over 48" and the center bearing wall was leaning 1-1/2" over 48". I firmly believe the lack of proper ceiling framing is probably contributing to this but I'm trying to figure out a fix for this woman. If the opposing walls were leaning away from one another, I could see pulling them in with come-alongs but this is a totally different story. Anyone ever come across this before and know of a possible approach toward resolving it. I could strengthen up the perpendicular walls to account for shear but I think we also need to pull these walls in a little more in addition to maybe reframing the ceiling. I think they have have positioned some roof load on the ceiling too by building those knee walls 4' in from the exterior walls...
