RADIAL TEXT
thanooj82
5
Hai,
i am using UG-NX8, i made radial text by using insert-curve-text-on curve.then i select the planar text,while selecting the text geometry it was not selected.which option i have to use to mill the radial text.
with regards
t.tanooj
I looked at your data, in nx8 I cold not read the big frame, tried in ST4, ST5 everything works fine. call report GTAC
regards
