It depends on the relative stiffness of the various items.
If you're building in a soft upper strata with large overall loads and settlements in the range that you'd generate loads on a shallow footing, then you're definitely getting load sharing. This is a floating pile system.
Your piles aren't going to a bearing strata, they're spreading load along the length and working to spread bearing area out deeper and wider. I've done rafted pile caps in soft clays under large tanks before and that sort of system really doesn't make sense looked at as individual piles, especially since overall group settlement is going to govern design. You also see various composite pile/soil systems that work in similar ways.
In more conventional systems where you're running piles into a stiffer strata, end bearing, or otherwise going to a generally stronger depth this isn't really the case. Your induced loads on the bottom of the raft will be much smaller. In these conditions, the upper soils are also likely to settle or consolidate under load more than the lower strata and the loads the raft takes through bearing may further reduce as part of that process.
