Bodgy Engineer
Hi All,
Firstly, id like to say I'm sort of stuck with Bentley systems. Unless I put a lot of effort in to convince others, and will likely take a long time.
Secondly, I have used STAAD a little, but cannot get over the horrendous user interface / work routine. I remember the first time I used it, getting the program to analyse a simply supported beam was a 15 minute odyssey!!!!
I really like the ram elements user interface, and general functionality. The only problem is, it is incomplete and Bentley do not seem to really prioritise it's development. They instead prioritise Staad!!!! ( I think it's a sunk cost mentality (from the user's of STAAD that is))
I don't really want to swap from Ram Elements, given the interoperability with Concept and SS, and it will be bitter pill to swallow when they finally develop Ram Elements to it's full potential (limited design codes, function's missing).
If I were to switch, what's the best alternative? I think Spacegass is very similar to Ram Elements, in terms of interface and workflow. I think it's more mature, and has more functions closer to STAAD, but without the horrendous interface.
Further to the point above, i need something easy to learn. We are likely to have junior staff come and leave, so a intuitive interface / workflow is a must.
I mostly model the following
[ul]
[li]free standing Structural steel - with spread footing analysis[/li]
[li]Industrial buildings - Tilt up, Steel, Suspended slabs[/li]
[li]Lattice towers and other lattice type structures[/li]
[/ul]
Most of the stuff is fairly simple, but there can be a bit of bulk to it.
Cheers
[ul]
[/ul]
Cheers
