Hi all,
I'm working through an example of distribution lateral load into shear walls depending on their relative displacement. The example is from Reynold's Concrete Design Handbook, but I am struggling to understand the derivation behind an equation they are using to calculate the amount of force going into each wall, and I don't like using an equation if I don't understand the physical meaning behind it.
Is anyone able to explain the attached equations? I figured it to calculate the force in each wall it would just be a case of multiply relative stiffness by F.
Thanks in advance
Thanks in advance
