Hi Folks,
This is rather a theoretical question for the experienced structural engineers. How do you guys assume the shear wall load transfer and the bending moment reinforcement consideration at the ends of a shear wall when only a portion of the wall is directly sitting on the foundation wall below ? The rest of the wall is sitting on a RC beam in some situations and in others it is directly on the ground floor slab so acting as a deep beam. You can consider half of the wall sitting directly on a foundation wall and the other half on a RC beam or ground floor slab. Also as a note the entire length of the wall is connected to the diaphragm/slab.
I would simply design the part that is bearing on the foundation wall as the shear wall and also consider the stiffness of that portion of the wall for the lateral load distribution even though the entire wall is actually not seperated. I would like to get some opinions about this. Has anyone of you encountered with such a condition ?
Thanks!
Thanks!
