breaking_point
When designing a RC slab, it is typical to spec the same reinforcement top and bottom. When analyzing this section, do you assume the concrete contributes nothing (i.e. a neutral axis of 0) when analyzing the stress blocks as the compression steel would balance the tension steel? As such, the moment capacity would be the force in the steel multiplied by the level arm between the T and C steel?
