What does anybody think about periodic re-torquing maintenance programs for bus joint and connector bolts in switchgear? Is it better or adequate to do periodic IR imaging and only retorque if a problem is suspected? I've heard arguments both ways.
When re-torquing should the bolts be completely loosened first, or just checked with a torque wrench?
Finally, is there a standard which specifies bolt torque for bus connections?
