atrizzy
- Mar 30, 2017
- 359
I have a condition where a set of trellis joists is being supported from the underside of a beam via heavy duty 1/4" wood screws. Therefore, the joists are being supported exclusively by tension/withdrawal/head pull-through of the screws.
The contractor forgot to install the necessary plate washers when installing the screws, so in the current condition the system fails in bearing/head pull-through.
What is the consensus on removing the screws and re-using them after installing the necessary washers? I'm, of course, concerned that a second install won't be as robust as the 'virgin' install. Since the system works on tension capacity alone, I don't want to compromise this load path at all.
I'm considering having them increase the screw size.
What does the group think about this?
Thanks in advance!
Thanks in advance!
