Sparky4598
- May 4, 2024
- 31
I'm looking for a good strong epoxy for doweling #5 rebar into 3000psi concrete that is 8" thick. Some Google searches later I came across Hilti Hit-Re 500 which seems to be one of the strongest available and has very clear and easy to read data sheets to understand the strength but it is stupid expensive.
Then I came across RedHead T7+ which is about half the cost but I am having a lot of trouble understanding the code approval data sheet that contains the strength data. It doesn't list strength in a table, but seems to give equations to determine the developed strength, but I am just not following how to solve them.
Can anyone help me understand the RedHead datasheet better and/or suggest an alternative epoxy for doweling rebar that is comparable in price or cheaper than the RedHead T7+ but still has as good or better strength characteristics?
I'm not really expecting to be able to achieve full tensile strength of the #5 Grade60 rebar with only 6"-7" embedment in 3000psi concrete, but the more the better of course. 75% strength would be desirable as the rebar is a bit oversized for this application and we are just using it because we had extra.
