jreit
- May 2, 2014
- 95
Hello.
I had a question about rebar hooks with different concrete strengths at a joint.
Specifically, I have a precast prestressed concrete beam with f'c = 8.5 ksi and a continuity diaphragm with a f'c = 4 ksi to make the system continuous.
I am using rebar for the positive restraint continuity reinforcement, i.e. the bottom steel at the connection between the continuity diaphragm and the end of the beam.
When I hook a #6 bar, my development length into the beam is much smaller (~24") than if I develop into the diaphragm (~36").
Does the hook behave the same way regardless of which side of the joint it is developed and which side of the joint has the 12db dimension.
Sketch linked below.
Link
Link
