Rebar Weight 2
mjohan
91
What is the weight of a piece of rebar? (#3, #4, #5, #6, #7, and #8)
I am also curious as to the comparitive price/ lb of rebar to W steel beam shapes. Just trying to get a feel for the cost with the rising steel prices.
Check the appendices to a steel handbook - also, I believe in AASHTO M31.
ACI318-99, appendix E lists rebar weights.
Vendors will send you a chart as well.
[pacman]
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See faq158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
#3 = .376 lbs/lf
#4 = .668 lbs/lf
#5 = 1.043 lbs/lf
#6 = 1.502 lbs/lf
#7 = 2.044 lbs/lf
#8 = 2.670 lbs/lf
#9 = 3.400 lbs/lf
#10 = 4.303 lbs/lf
#11 = 5.313 lbs/lf
