Reciprocating (0.5Hz max), 3-3000ml, Air Displacement component (Medical)
Helepolis
206
Hi all,
Working on designing a medical device that will ventilate a patient (displace air exhalation/inhalation cycle).
The requirements:
1. Frequency - max of 0.5Hz
2. Volume - min volume is 3ml, max 3000ml (doesn't have to be the same unit)
3. Medical grade
4. Force isn't an issue
So far from what i have learned, some devices use air bellows and some air cylinders.
I managed to find one manufacturer of such cylinders (Airpot.com) , after disassembling an old ventilator which uses Airpot's cylinder.
Any leads will be welcome (manufacturers, category name, specific products etc').
Best,
SD
A forum full of engineers and not a single lead for medical automation manufacturers?
I'm not clear on what exactly you're asking..
If you're looking for brand names of ventilators to tear-down (?) then ask a bunch of ICU nurses as they should know.
Keith Cress
kcress -
Looking for a component or manufacturer of such components (pumps,air cylinders, bellows, whatever...), that have medical standards and will provide the capability of air transportation (as described in the original post).
