BasakAbhishek
- Sep 5, 2006
- 35
I have to design a 2D array of tubes, where each tube is to be butt welded to corresponding stubs (also arranged in an array). I plan to weld the tubes row-wise. Hence, there will be access from one side only. Is there any guidelines regarding the minimum gap between the ODs of adjacent tubes? If not, what do you recommend?
Abhishek Basak
Abhishek Basak
