MechEngineer2012
Hello everyone,
Could you provide the recommended clearance (min and max) between the shaft and the packing ring (solid ring made graphite)? We are transitioning from split packing to a solid one-piece design for a pump. As the packing will be compressed, we need to ensure that the clearance between the shaft's outer diameter and the packing's inner diameter is not too high. Are there standard clearances for this and could you please share them? Thank you.
