Robert_spider
Hi to all,
I am new in the field of Steel/Aluminum Construction.
I have a fixed connection detail at the Bottom where the Square rectangular hollow section has to be welded to the base plate to create a fix connection.
I Have heavy moment.
Lateral Reaction
And Vertical (Axial) Dead Load.
I want to design the connection so I Want to know how can check the weld against the forces mentioned above and also what is the method (Formula/procedure) to design the weld.
Please do guide me.
Lateral Reaction
Please do guide me.
