TimSchrader2
Hello ... Does anyone know of a chart or link that gives the above for countersunk screws in single shear (as compared to hex heads)? When a CSK screw is in single shear the loads on the CSK angled faces induces moments that can rotate the head out of the countersunk hole. I have seen this happen. The angled faces contact the material imediately upon torquing, before the hole diameter would create bearing loads on the body of the screw. Especially if a large hole clearance was used. So, it makes sense that a CSK screw would not handle as much shear load as a hex head where most all shear is thru the body (neglecting clamping friction).
The exact solution is more complex as it would have to deal with the preload values and the K stiffness constant of the surrounding metal, which can be about 8 times the screw stiffeness constant. But I would think there would be a rule of thumb. It should be a certain % of the shear capacity of a hex head. I have seen a few charts that do not list any reduction. Which I believe are not accurate.
MIL STD HDBK-5H does address CSK rivets.
This is a 'remotely' similiar situation with pin bending (seperate topic). Which relates to bolt bending to some degree. Standard methods of assumed load distribution yield very conservative moments. I have one book that says too assume the loads as a point load at the centerline of the thickness of the 2 or 3 plates the pin goes thru. This gives results that are way too conservative, unless maybe for a bridge where that safety factor is justified. Using a FEA to better define the load distribution between the bearing surfaces gives more accurate results on pin bending. I have done some tests to verfiy this.
Thanks for any insights
Tim
Tim
