Hi, Eurocode 3 defines that if the design shear force is more than half the design shear resistance, then the combined effect of bending and shear is calculated by considering a reduced design strength. This reduced strength is calculated as fyr = fy × (1-ro). However, this reduction should only be made within the shear area. And here comes the problem which is not explained anywhere, how do I calculate one single (representative) design strength of the whole section to calculate the resistance to the combined effect of shear forces and moments? I know that eurocode 3 also defines another more complicated formula for calculating the design moment resistance considering the factor ro, but if I use this formula or apply the previously mentioned one to the whole section, the results are vastly different. The complicated formula barely reduces the strength, while fy(1-ro) greatly reduces it. Yet, I've seen calculations which take the fy(1-ro) for the whole section and go with that. This is obviously conservative, but is it justified to use it like that? What is the true way of calculating the strength of the whole section based on the reduced strength of the shear area and the non-reduced strength of the non-shear area?
