We're trying to reduce the available short circuit energy at the incoming terminals of an industrial control panel to be NEC Article 409 compliant.
A line reactor's manufacturer's literature said if you are looking to reduce the short circuit current like we are, to use an isolation transformer, not line reactors.
Line reactors work safely on VFD's, and they definitely reduce the current to acceptable levels, are easier to install, and a fraction of the cost of an isolation transformer - What is the issue?
