Regarding teamcenter 1
rahul683
Automotive
Apr 19, 2016
10
can any body tell me installation procedure for teamcenter?
what is oracle ?how oracle is configured to install team center?
I think you should call Siemens and ask for a training course of Teamcenter.
Or, have somebody assist you.
Installing Teamcenter is not "Click the install button and forget the rest".
- There are quite a few options you need to understand, select and specify.
Oracle is the underlying database ( or, one of the possible databases.)
Neither Oracle is "Click the install button and forget the rest".
Tomas
Installing Teamcenter is indeed not an easy task. And even after installing you need to configure your whole datamodel.
You have to know your business processes, requirements, ways of working etc.
Only relatively "simple" install is the Rapid Start option. but then you don't have the option to configure it to your needs.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hi Ronald
Is installing rapid start
Required to install Oracle. ?
Thank you.
No I don't think so. You should also be able to install it running on an SQL Database.
NX9 / TC10.1.2
