I'm having trouble with a sketch. There are certain Relations that just are not letting me do what I need to do. So how can I view all the relations to see what I need to delete. There used to be an add/remove tool. Now what is there?
If using the new sketcher, you likely won't be deleting constraints. Instead, you need to add dimensions or place "persistent" constraints. You have to remember to turn on the persistence function; otherwise, your constraint may be overridden by a future conflicting constraint/dimension. It's a whole new philosophy to get used to.
In a different thread it was stated that inferred relations were incorrectly taking priority over dimensions. Version 2306 has the option to switch between the old sketcher and the new one without restarting, and will automatically edit old sketches in the old app. Last word was to stick to the old sketcher for now. Still waiting for our IT to update us to 2306.
