NX1973
It has been a year or two since I remember using it but in drafting, when adding a note to the drawing, there was an option to add a relationship value from the model to your text (depth of feature, for instance).
Looking for it this morning the only options I see are Import/Export, Insert Text from File, and Save Note As Text File.
Has it been replaced? Can you still access component expression values in the text editor?
TIA!
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
TIA!
-Dalai Lama XIV
