Hi
I want to estimate the relay contact life that is switch some 120VAC solenoids.
The manufacturer provides a graph listing expected operations VS switching current. That's quite easy to follow if you have one solenoid being switched by the contact.
Question #1
But how do you determine the switching current if the contact is wired to (2) solenoids in parallel they each have slightly different inrush ratings? Do you take the sum of the currents from each solenoid?
Question #2
Do they take into consideration of arc destruction when these relay life curves are created? Meaning if surge suppressor is NOT applied, that's the life you should expect?
There are multiple lines on the chart for resistive and inductive loads for AC and DC.
Question #1
Question #2
