Reload? 2
insideman
286
I am having a problem with acad 2006. Something has gone bad, giving me garbled text or no text at all.
What dire consequences would occur if I uninstalled and reinstalled the software? Would I lose my drawings?
No it would not affect your drawing files.
You might try a "repair" first.
You will not lose your drawings. They should be saved in a safe place and backed up on tape or CD. Turn off your virus protection before you reinstall. Then reboot your pc when complete.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
For "repair" I was refeerring to the option using Windows Control Panel, Add or Remove Programs, Change, Repair.
But this is a guess, something to try before a complete reinstall. As ctopher mentions, better to use a repair if available on the install CD.
I have had problems with AutoCAD 2006 having installed some patches in the wrong order. A reinstall took half a day (to get all the right patches in the right order as I'm using C3D too) but gave me marked performance improvements.
Similar threads
