PAK_ENG
- Jul 20, 2020
- 12
Hi all. I have a reinforced concrete beam that has developed a significant crack on the bottom (almost 1/16").
With the size of the crack, the assumption is that the reinforcing steel in the bottom of the beam has yielded.
How would I calculate the remaining capacity of the beam? Is there a corresponding loss in cross sectional area of the steel once it has yielded? I'm using AASHTO LRFD code. Thanks!
