Good Morning, All,
I am using some Parker IQAN PLC's for some equipment out in the field. IQAN uses an RJ45 ethernet port for diagnostics and software updates and I am wondering if any of you would have suggestions of products that I could use to securely connect to these machines remotely. I believe that a cellular modem with a VPN would technically do the job, but maybe you all know of a specific product designed for the job?
I have considered using either or maybe , but I would like to know what other engineers have used for these scenarios.
Thanks in advance for your suggestions.
