L-H
- Nov 2, 2017
- 16
Hi all,
For existing residential buildings, the owners sometimes want to remove an interior wall, mostly at the kitchen or the living room to make the house more open. They would hire an engineer just to check if it is a bearing wall since that is the only thing they care about. For me it's not that hard to tell if a wall is a bearing wall (sometimes we need to cut holes into the ceiling drywall to see the joists above if necessary). But I also take into consideration if the removal of the wall would weaken the LFRS of the building. Modern houses have more open layout and more windows in the exterior walls so the interior walls could play an important role in the LFRS of the house. I'm just wondering if you guys do the same. For these small jobs, most of the time we would do a site visit and write a report to say if it is a bearing wall or not, and so we could not charge them much. But if we want to verify the effect of removal of the wall on the existing LFRS capacity, it will blow up the budget. Also, those jobs are often given to small sole proprietor structural engineers (or sometimes arch. and other disciplines trying to practice structural engineering). Many of those can tell if a wall is bearing wall based on experience but I doubt they know much about LFRS.
