Rene_I-deas_User
Hi All,
I have an TL assembly which uses a sub-assembly. I want to move all the components in the sub-assembly up to the top-level so that I can remove the sub-assembly level. Currently all the constraints between the components are at the sub-assembly level and when I try to move the components the constraints all stay at the sub-assembly level and fail.
Is there a way to move the components and their constraints up to a higher level?
In NX I-deas you can move the constraints between levels first and then move the components subsequently. this preserves all the constraints between the components...is there anything similar in NX?
