Remove underscores from BOM list NX 10 Drafting
pllmoreau
Member
CA
Hello
Is there a way to remove the underscores from a BOM list in NX 10 in the drafting. When I do a clone of my assembly to clean it up a litte, I put an underscore as suffixe in namming rule, but when I do the assembly drafting I don't want the underscore to appear in the part list (BOM).
Thanks in advance
The old trick is to use a space character as the suffix in the renaming rule; NX will perform the clone operation, but not add the space as a suffix. The new files will have the same names as the old ones (be sure to specify a new output folder).
www.nxjournaling.com
