am7553
- Dec 21, 2020
- 4
I am helping a friend determine a header size to replace a load bearing wall in a residence. It will be supporting the roof loading and attic loading since the ridge beam is supported randomly along the center bearing wall. These are my loads: SL = 20 psf, Roof DL = 10 psf, Attic LL = 20 psf, Attic/Ceiling DL = 8 psf. The span is 15 ft and the tributary width is 12.5 ft (ignoring the sloped roof is slightly longer). Based on my calculations I will need a 14" deep PSL or (2) 14" deep LVL's to support the load. Does this seem correct? I'm surprised how large the moment/deflection is. Also is framing a 14" deep header an issue with 2x6 framing above? Thank you
