Removing attribute 1
javaxp
Automotive
Jul 14, 2014
43
I have some parts that have some String attributes. I need to maintain the category and the name of these attributes, but the type should be Integer. With two of these attributes don't have problem (first I remove the attribute and then re-add it wih the correct type ), but there is one that can`t get to remove. It presents the icon "Template" on properties/attribute. ¿Any ideas?
Thanks in advance...
Javier
Hi cowsky,
You're right. I have managed to delete it from Attribute Templates menu > Part file.
Thank You, cowsky.
Javier
