SocklessJ
- Aug 24, 2017
- 50
My experience is in steel structures, but this question has to do with my house.
My living room has a cathedral ceiling, which intersects the main house at the gable end (see attached sketches). I’d like to open the wall between the living room and dining room. While my knowledge of light frame construction is limited, here’s what I’m thinking:
Vertical loads. The floor joists in the dining room run parallel to the gable end, so it’s basically a partition wall. But I’d still like to tuck an LVL behind the band joist.
Lateral Loads. This wall is probably functioning as an interior shear wall because nothing else provides shear resistance in this plane due to the windows. So instead of removing the entire wall (or adding two columns), I could leave 24” wide walls on either end. These could be sheathed with plywood and connected to the band joist & new LVL above to form a portal frame. This would be similar to the APA garage door portal frame details I came across.
Any thoughts?
Any thoughts?
