Rename parts
Mikedk64
DK
Hi.
Is there a easy way to rename parts in a assembly.
I have to rename all my parts in my assembly?
I just perform a "Save As" on every part. It's my method of part numbering and I use the file name itself in the BOM. Keeps the docs in lock step with the model.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
Look up Cloning both in this forum and in the NX help doc
When you rename, is the new name totally unique to the "old" name?
Yeah, cloning is good for dealing with an assembly level re-name of all parts.
Ex: a Job# prefix (or suffix) to your all existing part numbers.
Not sure but I think the "re-name" option may be limited to being used on one part at a time.
Dave
NX9, Win 7 Pro SP1
I use a script to rename a part:
Code:
Option Strict Off
Imports NXOpen
Imports NXOpen.UF
Imports System
Imports System.IO
Imports System.Environment
Imports System.Windows.Forms
Module Renomear
    Dim s As Session = Session.GetSession()
    Dim ufs As UFSession = UFSession.GetUFSession()
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim lw As ListingWindow = s.ListingWindow()
        Dim workPart As Part = s.Parts.Work
        Dim displayPart As Part = s.Parts.Display
        If workPart Is Nothing Then Return
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Renomear")
        Dim filename As String = ""
        Dim wpPath As String = workPart.FullPath
        filename = wpPath
        If (select_file(filename) <> DialogResult.OK) Then
            Return
        Else
            Dim partSaveStatus1 As PartSaveStatus
            Try
                partSaveStatus1 = workPart.SaveAs(filename)
            Catch ex As NXException
                lw.WriteLine("SaveAs of part " & filename & _
                    " failed with error code " & ex.ErrorCode & vbCrLf)
                lw.WriteLine(ex.ToString)
            End Try
        End If
    End Sub
    Public Function select_file(ByRef filename) As DialogResult
        Dim sfd As SaveFileDialog = New SaveFileDialog()
        Dim result As DialogResult
        sfd.Title = "Choose new part file name"
        sfd.AddExtension = True
        sfd.DefaultExt = "prt"
        sfd.FileName = filename
        result = sfd.ShowDialog()
        filename = sfd.FileName
        sfd.Dispose()
        Return result
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
Nice.... It works perfectly and a lot less effort. I've got a big job to re-name tomorrow and will put it to good use.
Thanks!
Dave
NX9, Win 7 Pro SP1
I need to learn some journaling. It's obviously a powerful tool and I've got to many tasks that could be executed at a key stroke.
Dave
NX9, Win 7 Pro SP1
