Renaming 1
erdemturan
4
I want to change part name of file in the a assembly files.
But the problem is, revision must be in more than 30 assembly files. (I guess. There is a opening file limit(13) in the pro engineer 2001) How can I solve this problem?. Is there a easy way of making rename without open all assembly files ?
Sory for bad english.
Please Help...
Hi Erdemturan,
Open all the assemblies and close them, do not erase session. Then rename the file. Open each assembly and check that the new name is in the assembly, then save each assembly. If you have Intralink, this would not be an issue. Intralink looks after all the renaming problems, so you can just rename.
Tofflemire
