charliealphabravo
What is your experience as to whether an EIFS system, in general, is repairable or not. For example, if the EIFS had to be stripped off down to the substrate (plywood/osb), could the substrate be prepared for reuse or would the substrate also need to be removed and replaced?
I am looking at a manufacturer's instructions for installation of a spray/brush/roller applied weather barrier (water based acrylic) which state the following:
"Substrate shall be clean, dry, and free of any deleterious material such as wax, oil, paint, dust and dirt which could negatively affect bonding."
I would think that if the old substrate is sound, that it could be sanded/washed/dried/primered as needed to meet the requirements of the spec. In this circumstance there might of course be some of the old weather barrier left on the sanded and cleaned surface, however, I wouldn't necessarily see it as incompatible with the new weather barrier.
TIA
TIA
