Alan CA
- Mar 10, 2018
- 95
Hi All,
This is a widely debated topic and I apologies if I'm repeating any similar conversations happened in the past.
How would you deal with rusted and corroded metal studs? By rusted I mean it's not as deep as corroded, and corroded is obvious. Will you clean and coat studs or will you replace once you see signs of rust and corrosion?
Any official or reputable sources on the topic?
