When replacing a CS 3/4" Thredolet with a 3/4" Sockolet, are there any special precautions to take? Is making up a new pup piece necessary? Run pipe size is 8" schedule 40. I know it is recommended to not weld over previously heat-affected zones in certain situations. The reason we are going through this is to slowly phase out our threaded thermal relief piping with socket welded. We may be able to seal weld the threads if cutting out the Thredolet and inserting a Sockolet is not recommended.
