A pressure vessel was removed from service 4 years ago. Due to some issues that developed from its removal, the plant wants to put it back into service. Are there any particular requirements for recommissioning an ASME VIII PV?
This particular vessel is a liquid knock-out drum for a reciprocating compressor inlet.
I only have the original U-1A form from 1987 (no, we most likely aren't going to buy a new one because of its age). The vessel U-1 shows Full RT and SA-182 F316L material.
With the U-1A form the only documentation we have for it, I would model the vessel to confirm required thicknesses and recommend a hydro test to the original 5438psi.
Let me know if you have any recommendations. Would a hydro even be needed? Maybe just some UT readings?
Thanks in advance.
Thanks in advance.
