Possible additional stress caused by extra expansion, possible material reduction in yield or strength, especially for cast materials, corrosion resistance,
So many possibilities that only the vendor will be aware of.
If this pump is on VSD, there may be further constraints on min permissible speed, which may require a recirc seal fluid cooler to keep the seal cool at low speeds.
