'Residence Time' in catalytic VOC removal
AlexEss
Automotive
Dec 23, 2015
28
What would normally be the design 'residence time' for gas flow through Platinum coated, ceramic honeycomb, catalyzer blocks ?
My understanding is in order for the catalytic reaction to take place, the off-gas must reside in the catalyst bed for a certain length of time -
I have heard time values of 0.5 -> 1.5 seconds as being acceptable.
To give some physical characteristics:
Off-gas volume = 6000 m3/hr ( 212,000 ft3/hr )
Off-gas temp = 400 oC ( 750 oF )
Catalytic bed
Surface area = 0.36 m2 ( 3.89 ft2 )
Bed depth = 0.3 m ( 1.0 ft )
If I'm correct, the time required to pass through the bed is c. 0.06 seconds.
Does this give sufficient reaction time ?
All comments and observations gratefully received.
Thanks in advance,
AlexEss
What are the units for this volume flow - actual m3/hr or standard m3/hr ( at 15degC, 1atm) or some other?
What about free pore voidage of the catalyst block - is this not in m3 of pore volume / m3 of block ? If so, what is the volume of catalyst in the reactor ?
Sometimes, residence time is more simply expressed in terms of the gross reactor volume occupied by catalyst, while you are assuming it is based on actual voidage of the catalyst - can you confirm with supplier?
George, thank you for your reply.
The units are actual m3/hr, not Nm3/hr
Regarding the catalyst block, the info I have from the 3rd party supplier is:
Matl = Cordierite monolith
Catalyst type = Platinum
Cell Density = 200 cpsi (cells per inch2)
Matrix = 150mmx 150mm x150mm
Design Temp = 320oC -> 420oC
Space Velocity = 37037 l/hr
Number of monoliths = 32 ( 2 layers of 4 rows of 4 blocks )
I think more information is required to determine the volume of catalyst in the reactor.
Thank you for any advice or comments.
Space velocity usually is superficial space velocity, but the units you've stated are not correct. It should be in m/sec or similar. So this parameter gives you cross sectional area of the reactor.
Tr. Va = Vreac = Areact. Lreact
Lreact = Va. Tr / Areact
Where Tr = residence time required, Va = actual gas flowrate, Areact = cross sectional area of reactor, Lreact = length of reactor.
George, thanks once again for your help.
I will let you know what the outcome is.
